Old 05-10-2005, 02:48 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Default 17 tooth will be ok
I have also a TKO600 with a 295/50-15 tire but a 3.54 rear end.
I am using the 19 tooth gear which is almost perfect, you would probably need one with 17 teeth. Its a white color gear.
The gear is a standard Ford item. I got mine from Standard Transmission.
Nothing sounds better than a Cobra in a Tunnel !
