Last I knew, SMALL BLOCKS only. If they made the BB announcement, I missed it. If you already own the Drive train, you may want to look at a Unique. I have a Backdraft, I love it. It has the 3.45 rear gear, I love that also. If Backdraft doesn't handle FE's, Unique does. I was originally going to build a Unique until Backdraft showed up with a roller at an affordable pricetag. If you have your heart set on a Backdraft, I'm sure Reg will show you one with a 408 stroker that will blow you away. You could probably sell you drivetrain pretty easy if it is a 427 side-oiler. Don't cancel your trip, you may be quite impressed with the Backdraft/small block combo.
Good luck.
tfarhood
