Old 05-12-2005, 09:36 AM
TedMiller TedMiller is offline
Cobra Make, Engine: Johnspeed, 408w, TKO600
If your gas gauge seems to work at all, the wires are connected. Can you get to the fuel sender/wires without dropping the tank? (thru the trunk?). If removal is ness, use the floor jack with a board on the jack saddle to help support the tank. When the tank is down/out pull the sending unit for inspection. Play with the float and verify gauge operation.
Ted.
