Old 05-13-2005, 01:40 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Pete, here's what I'm using and the brakes work great.
Stock MII booster direct from CR. Master cylinder is from the Ford M-2300-C late Mustang rear disk brake conversion kit. I'll get the PN for you if you want to go this route. It's from the '87 - '89 T-bird Turbo coupe, as are the rear disks. Brake lines come out the MC on the engine side, so installation is easier.
Front brakes are Stainless Steel Brakes Force 10 (A148 kit for MII). They use Grenada 11" rotors, and 4 piston calipers.
This 11" front, 10" rear disk setup fits 15" wheels, and works extremely well.
