Old 05-13-2005, 07:15 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally posted by Ford of France
Toploader with the 2.89 first gear--especially made for the lower rearend ratio cars. Available through David Kee.
Why would you buy an orphan ratio, as the common wide ratio version is 2.78 first gear (close enough that you would not be able to tell a difference), and the 2nd and 3rd gears are the same anyways. I'd stick to the standard wide ratio toploader 2.78 first if you want a wide ratio 4 speed.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
