Old 05-14-2005, 05:35 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Pretty easy to make your own...I did. Use brake line, 5/16 or 3/8 I forget which one fits the dip stick just right. then get the flare fitting for the size hole in the oil pan. Run the line anywhere you want up the side of the engine. Put the dip stick in, and put the right amount of oil in. Then just look at the dip stick and mark the oil level, so you know where full is. After brake is bent to where you want it, and you cut it to length, the dip stick fits perfectly.
Jack
XSSIVE .....
