I have an aluminum 496" Scat billet stroker with 58 mm TWM, FAST, MSD, and roller lifters and rockers on a .64 lift cam. The rev limiter on the MSD is set for 6800 rpm and I usually shift around 6500 rpm when I'm on it. No your not dreaming. It's flat scary. With 3.54 gears and a TKO 600 5speed it breaks 335/35/17's loose around 4400 rpm in 4th gear. It does get your attention.
