Old 05-15-2005, 09:51 AM
blykins blykins is offline
Have you got the timing chain off? If not, you need to remove it also....when you pop the cam gear off, you'll see the hole you need....there will be a dowel right next to it. To get the timing chain off, take the bolt out of the cam first.....then "walk" the gear off the dowel....you can leave the crank gear on for now.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
