Thread: CA Regist?
Old 05-16-2005, 10:20 PM
pgermond's Avatar
pgermond pgermond is offline
I wish you guys the best of luck, however, if a dual point distributor and/or multi-carbs were smog exempt it would have been discovered eons ago. If you do come up with a way around the CA registration process w/o using the current "acceptable" methods (i.e SB100), you should bottle and patent it - you will make a fortune.
Good luck!
Phil
http://www.uniquecobra.com/
