Cameron,
Does not bring back happy memories - wires wires wires!
Assuming we are singing from the same hymn sheet you should have 3 wires coming from the speedo
Red Speedo sender power supply +8.2V
Light blue / white speed INPUT pulsed from 0 to 12V
White speed OUTPUT pulsed from 0 to 12V
I think you are earthing out somewhere.
The sendor power seems fine in that if it was more than or less than 8.2V it would not work (assuming it does when driving)
Why have you not got the blue / white wire connected??????????
This should run through to your tranny (along with the output wire (white)
Is it not the case that because you have'nt connected it your speedo is playing up???????
I must be a guru as I've given a half decent explanation!
Mind you, to become a gur you must first suffer the pain (99% hard work and 1% genious).
I have a wiring cluster table for the Chaser AUI XR8, which I understand is similar to the AUII XR8. Let me know your E-Mail address and I'll send it.
Good luck and stop looking at those dials - they send you MAD!
PCC (Peter Craig)
Keep the sun shining
