Thread: Max Nos
Old 05-18-2005, 02:30 PM
Yetiman's Avatar
Yetiman Yetiman is offline
Cobra Make, Engine: Arntz/SBC/Jag
Sure. Question is, for how long.
The main issue is knock (detonation) control.
Are you able to run race gas ? what is the compression ? Are you willing to put in an ignition box that will retard the timing when on the squeeze? Are you running stock rods and crank, or something much stronger ?
If you were to design an engine around this in the first place, you would want moderate compression (10:1), a forged crank, forged I beam rods and forged pistons. You would want to be able to have control of the maximum ignition advance when the bottle is in use. You would also probably want to select a cam with nitrous in mind (Crane offers these among others).
At the very least, you want a good rev limiter
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
