I assume your shifting into 1st or 2nd FIRST to stop the trans gears from turning BEFORE shifting in reverse? If not, you can pretty well EXPECT reverse to grind a little bit because the trans gears, even in neutral will continue to "spin" for some time after the clutch is engaged.
