  #84 (permalink)
Old 05-19-2005, 07:44 PM
Three Peaks Three Peaks is offline
Alex, have you been able to figure out what your wheel setback will be with your suspension set up? What is your flange to flange measurement with these control arms?
I noticed that Pole Position has different length adjustable arms now and I can't remember what length adjuster tubes you used?
Are you going to use the 11" GM rotors with the Wilwood superlite calipers and Granada bracket? If not, what do you have in mind for your brake set up? I know you're setting your car up for racing, so I'm assuming you are going to go with larger brakes if possible- possibly the 13" rotors?
I was also hoping this thread would attract more home builders so there would be more information out there for newbies like me, but I guess we'll just have to try to keep it alive as long as we can.
Thanks for all the information and great pictures- Bob
