Wiring question for Classic Revivals
As the heading says I have a question.
For those guys who have done there wiring or are thinking about it, Where did you run the wiring through to the rear?
Ie : Where through the rear bulkhead did you go?
I am mounting fuse box and all wiring down left hand side of the car and can safely run the wires along the floor inside the cabin beside the sill, then around the post with the door striker mounted, but where did you go from there?
You can go through into the boot area by running the loom halfway up the rear bulkhead or did most people go through the bottom corner and through to the wheel well then up infront of the strut tower and through the side into the boot area?
Also on a side note I didnt think about it earlier but I will need to modify the wiring harness I bought as it is setup for the American way of things where they dont have seperate brake light wiring running down to the back of the vehicle.
Cruising in 5th
