05-22-2005, 08:09 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
J C Whitney makes a muffler very similar to the original CR mufflers, but that sound a little quieter and don't cost you quite as much power. They're pretty cheap too. If you don't mind a bity more noise than the originals go with Lobak auger style mufflers. Reasonably quiet and NO power loss..
