Old 05-23-2005, 10:04 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Interesting. I checked the circuit breaker, but I wasn't quick enough to catch it before it reset if it is the problem. But it may be the problem because the system powered up when I would open or close the hood, or jiggle any wires near it.
Done; I've placed the connections on a common terminal. I'll drive the car for awhile with the circuit breaker bypassed. But I'm sure you put it there for a reason such as protection against an overload. So what problem should I be aware of with the circuit breaker bypassed or can I eliminate it?
Thanks again for your help.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
