Thread: Sidepipes
Old 05-23-2005, 12:51 PM
jeffko's Avatar
jeffko jeffko is offline
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Default Sidepipes
I have a few questions about the sidepipe installation.
What is the general distance from the body to the sidepipe?
Do the sidepipes install all the way to the header spring retainer clips?
Has anyone had to shorten the sidepipes to get closer to the body so as to not be held back by the header spring clips?
How is the bracket attached to the frame to support the discharge end of the sidepipe. Drill & tap or thru-bolt.
How much clearance should there be around the pipes as they exit the body cutout.
Thanks guys.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
