First of all it does not have to be in the center, the magbase will travel in a concentric cirlce no matter where it is on the flywheel "also the flywheel does not even have to be there" you are true'ing the bellhousing to the pilot bearing on the crankshaft. The only thing the flywheel would do for you is give you a bigger spot to mount the magbase. No matter where you put the magbase as long as you have room for the dial indicator it will give you a true circle.
