Old 05-23-2005, 02:52 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
This new side mirror glass is not as extreme an angle as the paste on “Fish Eye” convex mirrors I have tried in the past. It also looks factory and not like the paste-on’s which protrude from the mirror bowl. It uses the original mirrors teardrop already mounted to the car. It is available in a 4” size; replacing the 3.5” original mirror bowl assembly. (I think both dia’s. are available) Depending how you have your mirror adjusted, you may need to double the thickness of the black plastic gasket between the mirror base and the body so the bowl does not contact the body. There is no more distortion in this mirror than on a main-stream car’s side mirror. You can also purchase the entire mirror assembly if you like from them, should the 4” diameter be and issue. There are many different mirror manufacturers and I have seen 3 of 4 different style mirrors on SPF’s….so the 4” option may not be for everyone….cut a paper 4” circle to answer that age old question…”Are you feeling lucky”
Hopefully the picture says it all, I have others if anyone needs them.
