Old 05-23-2005, 02:18 PM
2KWIK4U's Avatar
2KWIK4U 2KWIK4U is offline
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
Clois
Man, I would think your spindles would last for years or at least a couple hundred thousand miles. Since the bearing doesn't actually rotate on the spindle there shouldn't be any wear, unless they've locked up and spun at some point. I assume that you changed the races when you replaced the bearings. Since the bearings are tapered, I would put a flat washer between the nut and the tang washer and see if that out the slop. I wouldn't run it that way, but it would verify wheater its the spindle or hub. My hubs are aluminum and there may be some wear/damage there.
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
