Old 05-23-2005, 03:46 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Ah yes.... One more thing.... I also installed the polymer distributor gear that we were talking about in a past thread. I'd been chewing up distributor gears left and right. Anyway... I did drill a #60 hole in the galley plug in front of the gear as another member suggested and got a chance before my radiator mishap to put about 100 miles on the car. I pulled the distributor and cleaned the "plastic" gear off. You cannot see any wear whatsoever! It looks like it's never been in contact with anything at all......... I'm impressed..
