Old 05-23-2005, 04:50 PM
xlr8or's Avatar
xlr8or xlr8or is offline
Check the mfr recommendations for spring pressures on the new cam and compare that to what you have now if you know what they are. If you don't have that info contact Reed and see what they recommend for the cam you have and compare.
If the existing cam isn't too radical you are probably fine since the new cam is milder but beware if they are heavy springs and the new cam is a flat tappet type you may have break in issues on the new cam.
