Thread: side pipes
Old 05-23-2005, 05:06 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Without researching muffler manufacturers, J.C. Whitney sells the 36" x 4" x 2 1/4" glasspack blanks. Cut out the existing ones, and weld in the new ones. You'll have to shorten the collector, and turnout. Install a 3" - 2 1/4" adapter on the muffler inlet for transition flow.
Another tip would be to weld in a collecter flange after the J pipe so you can replace mufflers easier. You can then ceramic coat the inside and outside of the J pipe, just like the headers.
