Brad,
I pulled my brake hub off and noticed some silver grease and that is all wrong. I will be replacing the spindles and bearings tomorrow. When I race it I run it into the corners pretty hard and that may be the reason or I may have not got them tight enough the last time I had them off. I have never worn out spindles before.
I am just trying to get everything in order before my first race in a couple of weeks. I decided to go ahead and replace my upper and lower ball joints and my tie rod ends while I have everything apart. I don't like to hit walls! By the way how do you like your TKO 600?
Clois
"Let's roll"
"Be part of Something Good
