Old 05-23-2005, 11:55 PM
Keithc8 Keithc8 is offline
Default Pond MS aluminum blocks in stock
I just received four Pond Motorsports aluminum sideoiler blocks. These blocks come with billet main caps with ARP studs, dry cylinder sleeves, side oiler oiling system and a C5AE-P casting number. I can sell these blocks fully machined ready to assemble for 4995.00 with the ARP main and head studs included.
We pressure check all blocks, line hone blocks, hone lifter bores, check decks, bore and hone with torque plates, oil galley work for better oiling, install all oil galley and water plugs. ready to assemble.
We can also build a nice short-block with these blocks for 7995.00 including, fully machined block, Scat cast steel crankshaft, Scat or Eagle 4340 H-beam rods, JE custom forged pistons, Mahle rings, Federal Mogul or Clevite bearings, zero balancing, Comp Cams flat-tappet camshaft and Ford Racing double roller timing set with blueprint assembley spec sheet.
Let us know how we may help you with your project. Thanks, Keith Craft
Keith C
