Old 05-24-2005, 06:41 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Don,
Yeah. The wide ratio TL is a little too wide for me, but you can still have alot of fun on the track, and I bet the times are not much slower with the wide ratio trans, but when you come out of a turn, accelerate, and shift, it just seems like the split is a tad too wide, but hey, what do I know, just an amateur wannabe racer.
I get about 27-2800 rpm's @ 70 mph, although I do most of my cruising on local roads, 45-50 mph, with an occasional highway cruise.
I think you picked the perfect rear ratio, the 3.07, for your set-up, that is using the TKO600. The only other ratio I would consider using would be a 2.88.
Terry, with the close ratio TL, 1st is 2.32, and with a 3.07 rear, 1st gear multiplication is 2.32 x 3.07 = 7.12, overall gear multiplication. With a tremec, 2nd gear is 1.98, and with a 3.73 rear, 2nd gear multiplication is 1.98 x 3.73 = 7.39, and with the TKO600 with 1.89 2nd, 2nd gear multiplication is 7.05 . A little tall, but I don't think it would be a problem.
I think I'm going to give it a try. Maybe this fall or next year.
Thanks.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
