Thanks for your response, very informative. I do have the tubular front and rear set up with coil overs and Bryan said the 8" and 10" wheels will work fine. As you mentioned I do have to adjust the back spacing and I need to find out what tire size will give me the best look without rubbing. I would like to get the bigger tires for handling and looks. It sounds like the 235-60-15s will be on the front, as for the back I was wondering if 60 series tires would work or not. Does anyone have this set up so I can confirm compatiblity?
Thanks again,
Corey C
