Thread: No Clutch
Old 05-25-2005, 07:06 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
Jeffko,
If your slave cylinder has the bleed valve pointing down, you will not be able to get all the air out without taking the slave off the bellhousing first. If you have to do that, use a large C-clamp to hold the slave piston in while you bleed the line. My original slave was like that and I have since found a replacement slave that was a mirror image of the original so the bleed valve could point up. The problem is solved.
To fill the reservoir, get a small syringe to fill it with. When bleeding the line, only pump the pedal 3 times. You will need to re-fill the reservoir again before you bleed it any more or you will just suck air again and have to start over.
P.S. I have the "push" style slave.
tfarhood
