Burgs What intake are you running? You want to mount the sensor in the intake next to your coolant temp gauge probe. I have a Dove single plane intake, there are 2 holes in this manifold. You will get the best readings by keeping it near your thermostat housing. If not you could drill and tap a hole for the sensor in the water crossover by the thermostat . There should be a flat spot there. Rick Lake Ps some people mount them in the bottom of the overflow tank.
