Old 05-26-2005, 08:16 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default TREMEC for BBF w/ SHORT INPUT
OK, I have been trying to find out which supplier can set me up with a TKO 500/600 set up for a BBF (460) with the correct length short input shaft (about 6.5 inches I think) , I don't want to use the spacer that is available as the solution. Who has experience with a good TREMEC distributor that you an recommend from experience ??? Does TREMEC build one to this spec with the short input as a special order or do the TREMEC distributors do the mod themselves and swap out the input ? I am sure one of you have already tried this path ??
Thanks
Bill
"...some assembly required, ages 8 and up...... well that took longer than expected......
