Thread: Motor Mounts
Old 05-27-2005, 05:45 AM
mickmate's Avatar
mickmate mickmate is offline
Hi Bob, the CR prints give a dimension to the back of the block which is likely what you are after if your using the same tranny. The motor mounts on your motor I believe through bolt front to back with a saddle where the FE's use a stud that goes down through a plate. I'll get that number on the back of the block if I can figure where everything is between shop, computer, book shelf and work........?????
mickmate
http://www.actoncustom.com/
