Old 05-27-2005, 04:11 PM
Hankcar Hankcar is offline
Originally posted by TALW
I have an aluminum 496" Scat billet stroker with 58 mm TWM, FAST, MSD, and roller lifters and rockers on a .64 lift cam. The rev limiter on the MSD is set for 6800 rpm and I usually shift around 6500 rpm when I'm on it. No your not dreaming. It's flat scary. With 3.54 gears and a TKO 600 5speed it breaks 335/35/17's loose around 4400 rpm in 4th gear. It does get your attention.
Mike those TWM 427 kits with the 58s will flow 4408 CFM giving you ALL the power you will need.
