  #26 (permalink)
Old 05-27-2005, 07:56 PM
jerryweichers jerryweichers is offline
Banned
Cobra Make, Engine: P. O. of KMS 91,92,193,196,197,205,207,S024
cobracooter, ok since mr e. wood has stated that i am a moron. please enlighten me as you seem to have the credentials what is wrong with my approach . i use only grade 8 nat. fine or better ie aircraft. fit every thing for grip length. an washers under head and nut, torque using an nylocks unless the application will be subject to heat,then i use an locking nuts when i am finished with the car i put a few miles on it then nut and bolt the entire car retorque every thing , rebleed the brakes using dot 4, change all fluids and then enjoy . while building the car i have all suspension crack checked any plating is done by platers that do aircraft work so they know how to bake the part to take care of hydrogen imbrittlement, i deburr every hole ,dress every panel first with file then , sand even if the panel is edged with rubber and will never be seen . these cars if run with 427's and bronze bushings produce a lot of vibration and need to be properly looked after in my opinion so no amount of attention to detail is overkill . i would also value your opinion on forging vs billet alluminumvs fabricated tubuler steel considering proper build quality for critical suspension pieces thankyou in advance for your help, jerry
Past owner of:
KMS- 91, 92, 193, 196, 197, 205, 207 AND S024.
REAL SHELBY COBRA's OWNED
CSX 3355, 3358, 2200, 2571, 2295
GT40 #1086
