Old 05-30-2005, 04:56 AM
strictlypersonl strictlypersonl is offline
Originally posted by Wheels427
Update,I replaced the trailor adapter,as per trouble shooting guide, now everything works except now the brake lights are on all the time when ignition switch is on.They stay on even if you take the wires off the brake switch.The pink wire under dash is alive all the time when ig. switch is on.Any clues what's wrong now?Thanks
If the wires are disconnected from the brake light switch, the pink wire should be dead even if the brake switch is defective. Furthermore, the brake circuit power is dependant on the ignition switch being on.
I suspect that the "real" pink wire may be hiding elsewhere.
