Old 06-01-2005, 11:05 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
With a .68 5th gear, 26 inch tires and a stock 3.27 rear 70mph was at 2,000 PRM. I couldn't stand it because the engine had very little torque there. With a 4.10 rear instead I ended up at 2500 RPM to do 70mph. With the new tranny and a .87 5th and the original 3.27 back in I get a 2600 rpm to do 71mph... exactly where I wanted it since the new engine has max torque at 3,000 RPM. There's a great calculator for figuring out final speeds at specific rpms here... http://www.angelfire.com/fl/procrastination/rear.html
Hope this helps!
