06-02-2005, 01:07 PM
KY
You will either have to fab a bracket to hang off of the tranny mount....or make a bracket to hang off the frame rail. I did the latter with my SV. It's a box frame, but it's the same concept. I took a piece of solid round bar....drilled it and tapped it for the bolt that goes through the slave cylinder rod bearing.....and welded it to the frame rail.
