Old 06-03-2005, 07:21 AM
bremillard bremillard is offline
Cobra Make, Engine: shell valley, all aluminum 540 ci chevy
That's a bad choice for pumps on a street driven vehicle with or without a regulator. If you put any amount of miles on the car the pump will not last long. You need a fuel return back to your tank to prevent pump from dead-heading which heats up the fuel and burns up the motor on the pump. These pumps are also very noisy. I would go with a BG hot rod pump with a fuel returning regulator. You will have to run another line back to the tank. Either this or go with a street mechanical pump. -Bob
