Old 06-05-2005, 09:54 AM
cobra427mnsi cobra427mnsi is offline
Cobra Make, Engine: Classic Roadster with 427 center oiler
Default Don, another question: front end alignment
Hi Don,
It seems that I am bombarding you with alot of questions, but , I've got the "pour more money into the cobra" bug. Actually, like the rest, I am always trying to improve my car. Now to the real reason I posted.
I have had trouble with aligning and keeping aligned the front end. The trouble is that the one spec (cambor or castor or toe in/out) moves around while trying to adjust the others. Once adjusted it eventually moves over a period of time.
I have the 1992 version of the 427. I have seen from FinishLine a bracket that bolts to the mounting area of the upper control arm that allows for easy front end adjustment. Although I can't envision how they are attached.
What do you do for front end alignment on your turnkeys? Do you have anything like that offered at FinishLine on your updated 427 kit that I can buy ?
Any info would help.
Paul
life is short: eat dessert first !
