Old 06-05-2005, 07:43 PM
xlr8or's Avatar
xlr8or xlr8or is offline
The first question to ask is why is the motor in a different spot? Did they use different motor mounts? If the headers moved it's likely everything else did as well. It may just be the trans is kicked over in the back and needs to be aligned better. This could cause other problem with drive line alignment and linkages.
