Old 06-06-2005, 07:26 AM
DougD's Avatar
DougD DougD is offline
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
Default mini starter wiring
I have a Bosch mini starter to put on my 5.0. It has a solenoid mounted on it a la GM cars. My car has a separate fender-mounted starter solenoid as per most vintage Fords. The Bosch has a large pole on the solenoid where I assume the battery cable goes (from the fender-mounted solenoid). It also has a small spade type connection that I assume is to engage the starter. My question is how do I wire this up? Do I have to make a jumper somehow? If so, where to connect it, and how heavy should the jumper wire be?
The starter is made to fit this car, and came with no instructions.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
