Old 06-07-2005, 08:03 AM
chuckbrandt's Avatar
chuckbrandt chuckbrandt is offline
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default That's fine
That's fine. As a point of clarification only, not trying to twist your arm, I was offering the whole assembly. Anyway, here is what it looks like if you need ideas. Hose fitting is 2" and the thermostat says 75/70 degrees C, which I assume means it turns on at about 167 degrees F, off at 158 degrees F?
Chuck
Build website at www.chuckbrandt.com
