Originally posted by 4RE KLR
Well I got the yard mowed. I went to get some water out of the water dispensor on the frig in the garage and the water tank broke and started to flood the garage. I turned the water off and cleaned up a small water mess on the garage floor. Could you imagine if it was the iside frige two weeks ago and run the whole time. Lucky me.
That is why you should always turn the water supply line off at the source if you have an icemaker/water frig.. As well as turn off the water to your water heater...shut the power off too so you don't burn the heater out, and make sure your laundry washers water supply is also off if you are leaving for an extended stay...FWIW
