Thread: oil problems
Old 06-08-2005, 08:39 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
You might want to insert and remove the dip stick a couple of times and rotate it in a couple of different directions. If mine isn't inserted just right it only shows oil on the very tip indicating I'm down to about a quart out of 8. The first time it happened it scared the snot out of me.
DonC
