I have two sensing bulbs mounted on the top of the radiator. The problem is that when engine is shut down the hot water collects at the top of the raiator and unless master switch is turned off the fans come on and try to drain the battery. The car came with the smallest battery.It didn't take that much. And it has four fans that cover the radiatorcontrolled by two thermostatic switches.Also verry quiet.
Mike H
