alternator reads 10.5 volts?
i just replaced my battery thinking it was from sitting. i think my new one is loosing power. i hooked up a volt meter to positive post and it reads 10.5 volts. wierd thing, when i disconnect wire from positive post, and then check volts it reads 14.2 at 800 rpm. why does the volts weaken when the positive wire is connected? it also reads 10.5 volts at the battery posts. is it a bad alternator, or some ground problem???
