Old 06-13-2005, 11:16 AM
cmorejava cmorejava is offline
Cobra Make, Engine: Ferrari Spyder California
Default Complete and running 351w & Thunderbird IRS for sale.
For sale - 1974 351
Bored .030 over, stock pistons, compression ratio estimated at around 9.5 to 1.
74 cylinder heads, stock
Edlebrock “performer” intake manifold and camshaft & valve springs. Double roller timeing chain.
I also have the “Crane Fireball” horsepower camshaft that I first used but that is better used with a standard transmission. Almost too much overlap for an automatic. Nice roll at idle, torque comes it at about 3000 rpm.
1989 Electronic distributor, no internal advance, controlled buy Holley CPU.
Aluminum timing cover & timing tab new, no more than 1000 mikes.
High flow thermostat & modified (closed) water pump impeller.
Holley throttle body fuel injection (700 cfm), 4 bbl, originally 4DI cpu, now 950 commander. I have the 4DI CPU and can be converted back just by unplugging.
K & N air filter.
Fined aluminum valve covers.
Alternator, regulator, no more than about 5k miles
!993 Thunderbird IRS, complete.
Doug
