Same problem here. I tried adjusting the pin but ran out of adjustment. I had to slightly enlongate the hole which helped but the tape on the pin worked best. I also change out the weatherstripping on the door. Each end of the door had 1/8" thick weatherstripping while the sides and bottom had 3/8". I removed this and replaced it with the 3/8" all the way around. This helped snug up the door as well.
Rod
