Old 06-15-2005, 12:32 AM
Keithc8 Keithc8 is offline
Off set the rear seals between the cap and block, use a little silicone between the cap and the block at the bottem. Use the pieces that came with the Fel-Pro rear seal between the cap and the block. Use aerarobic[not spelled right] sealer on both sides of the rubber seals supplied and slide them in when you install the cap, making sure they go all the way down with the cap. Then drive the nail type parts down between the rubber side seals and the cap driving the pieces out against the block. Hope all of this makes sense. Good luck, Keith
Keith C
