Thread: Coil Mount
Old 06-15-2005, 05:42 AM
Rob_R Rob_R is offline
Club Cobra Member
Cobra Make, Engine: Superformance 496 FE side oiler TKO II
I am using a Ford Motorsports coil bracket. The bracket is chrome and it is mounted with 1 bolt. The bracket is slightly oversized for a MSD coil so I have a piece of bicycle inner tube between the coil and the bracket. You can not see the inner tube. With 1 bolt mounting, the bracket can be bolted onto the front of an Edelbrock FE head.
As SFfiredog pointed out earlier, the SPF polished stainless steel expansion tank is both gorgeous and stout, although pricey.
The March pulleys and aluminum alternator brackets can be purchased from any of the FE advertisers here on CC:
Keith Craft
Gessford Machine
Southern Automotive
Good luck,
Robert
