Boxhead,
Just a couple things about the fuel tanks and pumps.
If you run std tank without surge tank you will have problems with surge once fuel level gets low and your having a go around corners. I think this is what SLOTH is running but not sure if he has done any track work yet.
Ian was running an external surge tank with standard pump and has found the std FI pumps cark it as there is no back pressure. He is now runing external carbie pump (4 psi) to feed surge tank.
My set up is tank with internal surge tank that feeds external Bosch pump. Seems to work OK except for noise of the Bosch pump.
Phil.
